PROBLEM
In ArcGIS Pro, at times, text labels do not honor attributes with word spacing when callouts are defined. The image below shows the callouts on the map display with no word spacing.
The Word spacing property in the Formatting tab of the text symbol properties is set to 0%. Refer to ArcGIS Pro: Text symbol properties for more information.
Use the workflow below to change the word spacing property of the callouts.
Note: If the layer contains multiple label classes, select the required label class in the Class drop-down menu of the Label Class pane. Refer to ArcGIS Pro: Use label classes for more information.
The image below shows the text labels in the callouts honor the word spacing setting.
Article ID: 000025660
Get help from ArcGIS experts
Start chatting now
