PROBLEM
Unable to execute the Detect Objects Using Deep Learning tool in ArcGIS Pro
Last Published: May 27, 2021
When working with deep learning models in ArcGIS Pro, attempting to run the Detect Objects Using Deep Learning tool fails and returns the following error message:
Error:
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Parallel processing job timed out [Failed to generate table]
Failed to execute (DetectObjectsUsingDeepLearning).
Cause
When defining the environments for the Detect Objects Using Deep Learning tool, setting the Parallel Processing Factor environment causes a conflict because the Parallel Processing Factor pertains only to the central processing unit (CPU), not the graphics processing unit (GPU).
Solution or Workaround
Use either the GPU or CPU to run the Detect Objects Using Deep Learning tool. When setting the environment parameters for the Detect Objects Using Deep Learning tool, set the Parallel Processing Factor environment only if Processor Type is set to CPU. There is no need to set the Parallel Processing Factor environment if Processor Type is set to GPU. By default, the tools in the Deep Learning toolset use GPU processing to perform analyses. Refer to ArcGIS Pro: An overview of the Deep Learning toolset for more information.
The deep learning toolset in ArcGIS Pro does not support AMD GPUs.
The Detect Objects Using Deep Learning tool environment setting pane
If all else fails, restart ArcGIS Pro to reset the tool environments and run the tools.
Article ID:000025535
Software:
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
