PROBLEM
ArcGIS Dashboards does not display attachments in an embedded web map
Last Published: June 11, 2021
The pop-ups in ArcGIS Dashboards do not display information about features or rows from a layer in an embedded web map. In the image below, the attachments based on a layer's pop-up information are not available.
The ArcGIS Online Web Map point detail pop-up
Cause
The Enable Attachments setting of the embedded web map is not enabled in ArcGIS Online, as shown in the following image.
The ArcGIS Online layer details page without the Enable Attachments checked
Solution or Workaround
To turn on the Enable Attachments settings for an embedded web map in ArcGIS Online, refer to: ArcGIS Online: Allow Attachments
The ArcGIS Online layer details page with the Enable Attachments checked
Article ID:000025526
Software:
  • ArcGIS Online
  • ArcGIS Dashboards
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
