HOW TO
The Site Scan Flight for ArcGIS and Site Scan for ArcGIS LE mobile apps are registered and supported with ArcGIS Enterprise 10.8.1 portals and higher. If working with ArcGIS Enterprise versions 10.6.1 to 10.8, the following procedure is required to add the Site Scan for ArcGIS apps as registered applications within an ArcGIS Enterprise portal.
Note: This guide is not intended to allow publishing of content from the Site Scan Manager for ArcGIS web application to ArcGIS Enterprise. To enable this, request a connection from your Esri Customer Success Manager or Technical Support and provide them with your Enterprise portal URL and App ID.
Use the following steps to add Site Scan Flight for ArcGIS and Site Scan for ArcGIS LE as registered apps to ArcGIS Enterprise 10.6.1 and later:
https://webadaptorhost.domain.com/webadaptorname/sharing/rest
Note: The URL below must be manually typed into the address bar and cannot be accessed by clicking through the Sharing/REST web interface. In the following URL, [username] should be replaced with the aforementioned administrative user.
http://webadaptorhost.domain.com/webadaptorname/sharing/rest/content/users/[username]
["urn:ietf:wg:oauth:2.0:oob", " sitescan3dr://arcgisauth"]
https://webadaptorhost.domain.com/webadaptorname/portaladmin
Get help from ArcGIS experts
Download the Esri Support App
