Frequently asked question
How do I access authorization codes for ArcGIS software in My Esri?
Last Published: July 25, 2025
To authorize ArcGIS software with a Single Use, Concurrent Use license, or ArcGIS Server, an Authorization Code is required. This code is normally emailed when you purchase the software, but if the email was not received or cannot be found, the Authorization Codes are available at any time in My Esri.
Requirements:
There are two ways to obtain the Authorization Numbers. Navigating directly to Authorizations, or preparing an Organization report.
Accessing through Authorizations
  1. Navigate to My Esri. Once logged in, the Organization Profile screen is presented.
  2. Select the Licensing tab, as shown in the image below, and look for the Authorizations option under the License Information section.
V Overview Users Transactions Licensing License Esri Products Generate the license files you need to authorize your software. Start Licensing LICENSE INFORMATION License Summary Authorizations ArcGlS Enterprise ArcGlS Online LICENSE FILES LICENSING TOOLS
  1. On the Authorizations page, filter by Product, License Type, Available Authorizations, and Versions to get the Authorization Number for the desired software.
  1. To see the Authorization Number, simply expand the product section
Preparing an Organization Report
  1. Navigate to my.esri.com and sign in with your My Esri account, as shown in the next image.
My Esri login panel
  1. From the My Organizations page, click Reports.
  1. On the Organization Reports page, click the Licensing option, Select a report option, and choose Authorizations from the drop-down list.
  1. The Authorizations report lists your organization's products, versions, license types and authorization numbers, as shown in the image below.
Article ID: 000025265
Software:
  • ArcGIS Pro
  • ArcGIS Online
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
