PROBLEM
Unable to edit utility network data with attribute rules in ArcGIS Pro 2.7
Last Published: April 7, 2021
Attempts to edit utility network data with attribute rules in ArcGIS Pro 2.7 fail, and in some instances, return the following error message:
Error:
Failed to create new feature(s).
Failed to evaluate Arcade expression. [GlobalID: {00000000-0000-0000-0000-000000000000}, Arcade error: General evaluation error]
One of the error messages that may be returned when editing the Utility Network Data with Attribute Rules.
Cause
The ‘Exclude from application evaluation’ option is not checked in the Execution section of the Attribute Rules view in ArcGIS Pro 2.7.
Solution or Workaround
To resolve the issue, complete the workflow below.
If the utility network service is running, open ArcGIS Server Manager and stop the utility network service before proceeding with the workflow below. Refer to ArcGIS Server: Stop a service in Manager for the steps to do so.
  1. In ArcGIS Pro, open the Attribute Rules view. Refer to ArcGIS Pro: Open the Attribute Rules view for steps to do so.
  2. Select the rule, and navigate to the Execution section of the rule properties in the details pane.
  3. Check the Exclude from application evaluation check box to enable editing the utility network data with attribute rules.
The example of the ‘Exclude from application evaluation’ option is checked in the Execution section in the Calculation rule properties window.
  1. On the top ribbon, click the Attribute Rules tab, and click Save to save the changes.
Saving the changes made to the rule properties to enable the editing.
  1. Repeat steps 2 to 4 for each feature class.
  2. Start the service in ArcGIS Server Manager. Refer to ArcGIS Server: Start a service in Manager for the steps to do so.
  3. Close and reopen ArcGIS Pro for the changes to take effect.
Article ID:000025256
Software:
  • ArcGIS Utility Network
  • ArcGIS Pro 2 7 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
