HOW TO
Export selected features from a feature layer in ArcGIS Pro
Last Published: December 5, 2023
Summary
Exporting a feature layer is one method of backing up data so editing, analyzing, or querying data without changing the original data is enabled. In some cases, instead of exporting the entire feature layer, it is necessary to export selected features from it, as the editing or analyzing data requires only certain features from the feature layer.
This article provides a few workflows to export selected features from a feature layer in ArcGIS Pro.
Procedure
Use Export Features
  1. Open the ArcGIS Pro project containing the feature layer, and select the features using either one of the following methods:
  1. In the Contents pane, click the feature layer. In this example, Contour is selected.
List of feature layer in the Contents pane where a feature layer name Contour is selected.
  1. On the ribbon, click the Data tab on the Feature Layer contextual tab set.
The Feature Layer contextual tab set on the ribbon consisting three tabs, Appearance, Labeling, and Data where the user must click the Data tab.
  1. In the Export group, click Export Features to open the Export Features window.
The Data tab showing the Export group with two options, Export Features and Export Table where the user must click Export Features.
  1. Configure the Export Features parameters as follows:
    1. Select the feature layer from the Input Features drop-down list. In this example, Contour is selected.
    2. For Output Location, click Browse….The Browse icon. to specify the location for the output feature class.
    3. Specify Output Name.
    4. Click OK.
Export Features window with the parameters to be filled which are, the Input Features, Output Location, Output Name, and click OK.
The image below shows the new feature layer, Contour_Elevationmorethan300m is created from the selected features and displayed on the ArcGIS Pro map.
A new feature layer named Contour_Elevationmorethan300m created from the selected features, and is displayed in an ArcGIS Pro map.
Use the Feature Class To Feature Class tool
The Feature Class to Feature Class tool was deprecated at ArcGIS Pro 3.2. Use the Export Features tool to perform this operation.
  1. Open an ArcGIS Pro project containing the feature layer, and select the features using either one of the following methods:
  1. In the Geoprocessing pane, search for the Feature Class To Feature Class tool, and click it. Refer to ArcGIS Pro: Run a tool in the Geoprocessing pane for steps to do this.
In the Search box in the Geoprocessing pane, type Feature Class To Feature Class and click the first option.
  1. In the Feature Class To Feature Class pane, configure the Parameters tab as follows:
    2. For Output Location, click Browse…. The Browse icon. to specify the location for the output feature class.
    4. Click Run. The new feature class created by the Feature Class To Feature Class tool is automatically added to the map.
In the Feature Class To Feature Class pane, there are two tabs which are Parameters and Environments where the user must fill in the Parameters for Input Features, Output Location, Output Name and click Run.
The image below shows the new feature layer, Contour_Elevationlessthan300m is created from the selected features and displayed on the ArcGIS Pro map.
A new feature layer named Contour_Elevationlessthan300m created from the selected features, and is displayed in an ArcGIS Pro map.
Use the Copy Features tool
  1. In the Geoprocessing pane, search for the Copy Features tool, and click it. Refer to ArcGIS Pro: Run a tool in the Geoprocessing pane for steps to do this.
In the Search box in the Geoprocessing pane, type Copy Features and click the first option.
  1. In the Copy Features pane, configure the Parameters tab as follows:
    2. Provide a name for Output Feature Class, and click Browse…. The Browse icon. to specify the location for the output feature class.
    3. Click Run. The new feature class created by the Copy Features tool is automatically added to the map.
In the Copy Features pane, there are two tabs which are Parameters and Environments where the user must fill in the Parameters for Input Features and Output Feature Class, then click Run.
The image below shows the new feature layer, Contour_Elevationmorethan500m is created from the selected features and displayed on the ArcGIS Pro map.
The new feature layer named Contour_Elevationmorethan500m created from the selected features, and is displayed in an ArcGIS Pro map.
Article ID: 000025141
Software:
  • ArcGIS Pro
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
Esri Support AI Chatbot
