PROBLEM
The Extent Indicator button is disabled in ArcGIS Pro
Last Published: September 6, 2021
In ArcGIS Pro, the Extent Indicator button in the Map Frames group on the top ribbon is disabled when attempting to add the extent indicator to the page layout.
The following image shows the disabled Extent Indicator button.
The disabled Extent Indicator button in the Map Frames group
Cause
  • This is by design. Extent indicators require at least two map frames with one frame containing the extent indicator and the other, the extent to be displayed. The Extent Indicator button is disabled until at least two or more 2D map frames are added to the page layout.
  • The page layout is corrupted.
Solution or Workaround
Choose one of the options below depending on the cause to resolve the issue.
Add map frames to the page layout
In ArcGIS Pro, add at least two 2D map frames to the page layout. Refer to How To: Set up a page layout with multiple map frames that reference the same data for steps to do so.
Create a new page layout
In ArcGIS Pro, create a new layout, and add the map frames to enable the Extent Indicator button.
The following image shows the Extent Indicator button enabled in ArcGIS Pro.
The Extent Indicator button is enabled in ArcGIS Pro
Article ID:000025084
Software:
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
