PROBLEM
When using ArcGIS Survey123 Connect to publish a survey, a folder of the survey is created in ArcGIS Online containing the feature layer, as well as a form item and a web map. This allows for flexibility in migrating the ArcGIS Online content. In some instances, when updating and republishing the survey using Survey123 Connect, the publishing process loads but does not complete, as shown in the image below:
This issue occurs when the form item of the survey has been moved to another folder in ArcGIS Online. This results in the item ID of the ArcGIS Online folder where the form item is to not match with the ID in the local ITEMINFO file of the survey.
When the survey is originally published, the ID of the ArcGIS Online folder where the form item is stored is saved locally in an ITEMINFO file. Every time the survey is subsequently published, the ID in the ITEMINFO file must match with the ID of the ArcGIS Online folder that stores the form item.
To resolve the issue, follow the steps below to edit the the survey's ITEMINFO file to ensure the item ID matches the ArcGIS Online folder ID where the form item is stored.
Article ID:000025001
Get help from ArcGIS experts
Download the Esri Support App
