ERROR
Attempt to Configure Data Store Failed. Caused by null
Last Published: March 3, 2021
Error Message
When attempting to configure the Data Store, there is an error registering the Data Store with the error message:
 "Attempt to Configure Data Store Failed. Caused by null"
Cause
This issue may be encountered when a Data Store that has been previously registered must be re-registered.
Solution or Workaround
It is strongly recommended to backup your data before proceeding.
Check the arcgisdatastore/etc folder. If there is a relational-config.json or tilecache-config.json file:
  1. Stop the Data Store service.
  2. Rename the .json files.
  3. Restart the Data Store service.
  4. Attempt to configure the Data Store again.
Article ID: 000024922
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
