HOW TO
Improve image quality in ArcGIS Survey123 feature reports
Last Published: May 10, 2022
Summary
When generating feature reports from ArcGIS Survey123, the images attached in the survey forms are of low quality. This article describes the workflow to improve the quality of the images in ArcGIS Survey123 feature reports.
The following example image is an image with low quality in an ArcGIS Survey123 feature report.
Image of a house in low quality in an ArcGIS Survey123 feature report
Procedure
  1. Open the desired survey form in the ArcGIS Survey123 website, and download the sample template. Refer to ArcGIS Survey123: Report templates.
  2. Open the downloaded sample template, and navigate to the image section.
  3. Add getValue:"" to the expression. In this example, getValue:"" is added to the expression in the picture section.
Image of getValue:"" added to the expression in the picture section
  1. Save the changes.
  2. In the ArcGIS Survey123 website of the desired survey, click Data > Report > Manage templates.
Image of the Report window
  1. In the Manage Templates window, click New template to upload the edited template.
  2. Close the Manage Templates window, and generate the feature reports.
The following image displays the example image with improved quality in an ArcGIS Survey123 feature report.
Image of a house with improved quality in an ArcGIS Survey123 feature report
Article ID: 000024860
Software:
  • ArcGIS Survey123 Website
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
