HOW TO
The font, size, and color of text symbols in ArcGIS Pro projects can be customized according to the context and theme of the map. However, changing the font size of text in shield marker symbols does not automatically resize the shield marker symbol accordingly.
The image below shows the shield symbol before the size of the text is changed.
The image below shows the shield symbol after the size of the text is changed (under Labelling Properties > Symbol > Appearance).
Follow the workflow below to resize the shield marker symbol using the labeling properties.
Article ID: 000024850
Get help from ArcGIS experts
Download the Esri Support App
