Frequently asked question
Is it possible to display a layer with more than 200 unique values and 10 colors in Map Viewer?
Last Published: April 6, 2021
Answer
Yes. Although ArcGIS Online: Types (Unique symbols) states there is an absolute limit of 200 unique values with 10 unique colors to differentiate the types of categorical data, it is possible for Map Viewer to display datasets with more than the set limit of unique values and colors.
The limitation only applies when creating a layer style through ArcGIS Online Map Viewer. When a style is created for a dataset with more than 200 unique values in Map Viewer, the remaining values are placed under the 'Other' category, with 10 colors representing the multiple categories. For example, the image below shows the layer has more than 200 unique values but is represented by only 10 colors when using Change Style in Map Viewer.
Layer with more than 200 unique values but only showing 10 unique colors in Map Viewer.
However, datasets can have more than 200 unique values or 10 unique colors in ArcGIS Pro or ArcMap. The image below shows the layer has more than 200 unique values and is represented by more than 10 colors.
Layer with more than 200 unique values represented by more than 10 unique colors in ArcGIS Pro
The unique values and colors can be displayed in ArcGIS Online Map Viewer by sharing the layer as a web feature layer or in a web map, as demonstrated in the image below.
The same layer from ArcGIS Pro with more than 200 unique values displaying in Map Viewer with more than 10 unique colors.
Article ID:000024837
Software:
  • ArcGIS Online
  • ArcMap 10 x
  • ArcGIS Pro 2 x
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
