PROBLEM
When attempting to edit attribute tables in ArcGIS Online Map Viewer, double-clicking the value in a field fails and the field is not editable.
The following are known causes for this issue:
Depending on the cause, use one of the options below to resolve the issue.
Update the member’s default role or custom role to enable the privilege to edit features
Note: Only administrators can perform the following workflows.
Enable the editing capabilities of the hosted feature layer
On the item details page, enable editing of the hosted feature layer. Refer to ArcGIS Online: Allow others to edit for more information.
Note: For public hosted feature layers, enable the Public Collection Data option before enabling editing. Refer to ArcGIS Online: Allow editing on public layers for more information.
Configure the pop-up settings to enable editing of the locked field
In Map Viewer, configure the pop-up settings to enable editing of the locked field in the attribute table. Refer to How To: Enable editing of a locked field in ArcGIS Online Map Viewer for more information.
Note: Alternatively, owners or administrators can make edits to the hosted feature layer’s data through the Data tab on the item details page. Refer to ArcGIS Online: Work with attribute data for more information. This workflow does not require enabling editing capabilities for other members.
Publish the feature layer as a hosted feature layer in ArcGIS Online
Publish the feature layer as a hosted feature layer, and configure the editing settings to allow other users to edit the attribute table in Map Viewer.
Get help from ArcGIS experts
Download the Esri Support App
