ERROR
json.decoder.JSONDecoderError:Expecting value: line 1 column 1
Last Published: August 24, 2024
Error Message
Running an ArcGIS API for Python script that requires signing in to Portal for ArcGIS may fail and return the following error:
Error:
Error return in the Python console when running the script to log into Portal for ArcGIS
Cause
This error occurs when attempting to connect to Portal for ArcGIS using the domain name server (DNS) alias and the portal is authenticating through a web-tier authentication (IWA or SAML).
Solution or Workaround
To solve this issue, use the fully qualified domain name (FQDN) to connect to the portal.
gis = GIS("https://<machine.domain.com>:7443/arcgis", "username", "password", verify_cert = False)
For portals authenticating through web-tier authentication, using the FQDN with port 7443 is the only workaround for this issue, and users are unable to use DNS within the script.
The script sample of connecting to the portal using the FQDN
Article ID: 000024610
Software:
  • Portal for ArcGIS
  • ArcGIS API for Python 1 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
