PROBLEM
In ArcGIS Online or Portal for ArcGIS, when configuring the logo of an ArcGIS Web AppBuilder app, the ‘Organization shared’ option is checked, but the logo is not displayed, or the app logo displays as a broken image.
The image below shows the organization shared logo is unavailable.
The image below shows the app logo displays as a broken image.
The known causes for this issue are as follows:
Depending on the cause, use one of the options below to resolve the issue.
Note: Only administrators can perform the following workflows.
Upload the logo in the organization’s Shared Theme setting
In ArcGIS Online
Note: The Shared Theme logo is automatically rendered in newly created ArcGIS Web AppBuilder apps.
In Portal for ArcGIS
Share the organization’s Shared Theme logo with the public
Note: It is not possible to recover a deleted item in ArcGIS Online or Portal for ArcGIS. A preventive measure is to enable the ‘Delete Protection’ setting for the item. Refer to ArcGIS Blog: How to prevent accidental deletion for more information.
Article ID: 000024514
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
