PROBLEM
The modified field aliases are not preserved in ArcGIS Pro
Last Published: July 18, 2023
In ArcGIS Pro, it is possible to modify the field aliases of a feature layer in the fields view, and save the changes on the map. However, after removing the feature layer from the Contents pane, and re-adding it to the map from the project's geodatabase in the Catalog pane, the modifications are not preserved.
Cause
There are two types of field aliases: feature class field aliases (geodatabase only) and layer field aliases. When opening the Fields view from the Contents pane top ribbon, or attribute table, the edits are made to the layer field aliases. Therefore, the changes are only saved at the feature layer level.
Solution or Workaround
Modify the field aliases at the feature class level
  1. In the Catalog pane, click Project > Databases.
  2. Click the project's geodatabase. In this example, the geodatabase is 'Field_Alias_Test.gdb'.
  3. Right-click the desired feature class. In this example, the feature class is 'WA_Road'.
  4. Click Data Design > Fields. The Fields view opens.
Selecting Fields from the Data Design options in the menu from the Catalog pane.
  1. In the Fields view, in the Alias column, modify the desired field aliases. In this example, TYPE and NAME are modified to ROAD_TYPE and ROAD_NAME.
The Fields view of the feature layer.
  1. On the top ribbon, on the Fields tab, click Save.
The modified field aliases are preserved at the feature class and feature layer level.
Article ID:000024417
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
  • ArcGIS Pro 3 0
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
