PROBLEM
In some instances, sharing a package in the Create Project Template or Create Vector Tile Package pane fails, and the sharing process cannot be canceled in the Job Status pane in ArcGIS Pro. Force closing ArcGIS Pro does not cancel the job as the sharing process restarts after reopening the application.
The sharing process runs in the background, allowing users to work with ArcGIS Pro. Closing ArcGIS Pro does not end the sharing process as it is a separate process from the jobs processed in ArcGIS Pro.
If attempting to cancel the task in the Job Status pane fails and the task is still running, end the ArcGISSharingServer.exe process in Windows Task Manager by following the steps below.
Note: The same process is listed as SharingServer DLL in some cases.
Article ID: 000024380
Get help from ArcGIS experts
Download the Esri Support App
