ERROR
Untrusted Host. This server could not prove itself; its security certificate is not trusted by your OS
Last Published: November 5, 2020
Error Message
In some instances, working in ArcGIS Collector while connected to ArcGIS Online on a mobile device returns the following error message:
Error:
Untrusted Host. This server could not prove itself; its security certificate is not trusted by your OS.
Cause
The mobile device does not trust the ArcGIS Online certificate. This issue may occur intermittently on some user devices within an organization.
Solution or Workaround
To solve this issue, download the organization's ArcGIS Online certificate, and install it on the mobile device to force the device to trust the certificate and connection.
  1. On a computer web browser, sign in to ArcGIS Online. Refer to Sign in for more information.
  2. Click the padlock An image of the lock icon. icon next to the address bar, and click Certificate.
  3. In the Certificate window, click the Details tab, and click Copy to File.
Image of the certificate window.
  1. Click Next through the prompts, and browse to a folder on the machine to save the certificate file. Click Finish to export the certificate.
  2. Copy the exported certificate file to the mobile device, and install the certificate. Refer to Install a SSL Certificate on a mobile device for steps to install the certificate.
Article ID:000024329
Software:
  • ArcGIS Online
  • ArcGIS Collector
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
