PROBLEM
In ArcGIS Pro 2.6, the Feature Dataset option in the Catalog pane is disabled when attempting to create a new feature dataset.
The following image shows the disabled Feature Dataset option.
This is known behaviour after the ArcGIS Pro 2.6 update, which renders users with a Basic license unable to select the Feature Dataset option. This issue is logged by Esri as a defect. For more information, refer to BUG-000133417 and BUG-000132678.
Use one of the methods below to resolve the issue.
Use the Create Feature Dataset tool
The following image shows a new feature dataset is created.
Upgrade to a Standard or Advanced license for ArcGIS Pro on the machine
Upgrade to a Standard or Advanced license to enable the Feature Dataset option for selection in ArcGIS Pro. Refer to ArcGIS Pro: How to get ArcGIS Pro licenses for more information.
The following image shows the Feature Dataset option is enabled in the Catalog pane in ArcGIS Pro 2.6 with a Standard or Advanced license.
Article ID: 000024260
Get help from ArcGIS experts
Download the Esri Support App
