HOW TO
A significant change to PostgreSQL 12 and later is the removal of the special behavior of internal OID columns. Tables can no longer be created using the WITH OIDS clause, as described in the PostgreSQL release 12 notes . Prior to PostgreSQL 12, certain geodatabase system tables in PostgreSQL were created using the WITH OIDS clause. Refer to the solution section for information on how to upgrade your geodatabase when using a PostgreSQL 12.x instance.
Please note the following points related to this change while working with ArcGIS:
Failed to create feature class. DBMS table not found [ERROR: relation map.i48 does not exist]
Certain editing operations also fail when using an earlier client to edit data in a geodatabase in PostgreSQL 12 or later.
Using pg_dump/pg_restore for upgrades to PostgreSQL 12
There are several options for creating backups of PostgreSQL databases. However, for PostgreSQL databases used to store geodatabases, Esri recommends you use pg_dump to create an archive file, drop the database, re-create the database with the same name, and restore to the re-created database using pg_restore. This backup and restore methodology can be used before or after upgrading the geodatabase to ArcGIS version 10.8.1 or ArcGIS Pro 2.6. You can upgrade directly from a 10.6.x, 10.7.x, or 10.8 geodatabase if your database is at a supported release for ArcGIS Pro 2.6 or ArcGIS 10.8.1.
Article ID: 000023982
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
