HOW TO
This article provides steps to update ArcGIS Survey123 Connect by installing the latest version of the app.
Note: While it is not required, Esri recommends uninstalling previous versions of ArcGIS Survey123 Connect before installing the new version.
Note: Installing a new version of Survey123 Connect does not overwrite previous versions if they are not installed on the same directory. Multiple versions of Survey123 Connect may exist on different directories, and could be useful for troubleshooting. However, Esri only supports the latest versions of Survey123 Connect.
Article ID: 000023877
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
