PROBLEM
The basemap gallery is empty in ArcGIS Pro
Last Published: July 19, 2023
In ArcGIS Pro, the basemap gallery displays a blank window with the message, 'No Basemaps available'.
Image of an empty basemap gallery
Cause
The known causes for the problem are as follows:
  • The Esri default basemap is not selected as the basemap gallery.
  • A custom group without any basemap is selected as the basemap gallery.
Solution or Workaround
Depending on the cause, use one of the following options to resolve this issue.
Only an organization's default administrator or a custom role with administrative privileges can perform the following workflows.
  1. Log in to ArcGIS Online.
  2. Navigate to Organization > Setting > Map > Basemap gallery.
  3. Under Group, click Edit Image of the Edit button, and select Esri Default from the drop-down menu.
Image of the Basemap gallery setting in ArcGIS Online
Share the Esri default basemaps to the custom group.
  3. Under Group, ensure the custom group is selected, and click Share vector basemaps or Share raster basemaps to share the Esri default basemaps to the custom group.
Alternatively, create custom basemaps and share them to the custom group. Refer to ArcGIS Blog: Create a custom basemap gallery for your organization for more information.
The image below shows theĀ basemaps displayed in the basemap gallery in ArcGIS Pro.
Image of the basemap displayed in the basemap gallery in ArcGIS Pro.
Article ID:000023868
Software:
  • ArcGIS Online
  • ArcGIS Pro 2 x
Download the Esri Support App
Get help from ArcGIS experts
Contact technical support
Go to download options
