ERROR
Publishing failed to complete. Item does not exist or is inaccessible. Error code: 400
Last Published: May 12, 2022
Error Message
Republishing a survey from ArcGIS Survey123 Connect to ArcGIS Online, Portal for ArcGIS or the ArcGIS Survey123 website fails, and returns the following error message:
Error:
The error message
Cause
The survey form is deleted in ArcGIS Online, Portal for ArcGIS, or in the ArcGIS Survey123 website.
Solution or Workaround
Complete the steps below to resolve the issue.
  1. Open ArcGIS Survey123 Connect.
  2. Browse to the survey, click the ellipsis, and click Save as.
The survey in Survey123 Connect.
Alternatively, click Download, and create a new survey using the downloaded XLSForm.
  1. In the Create new survey from <Survey_Name> window, specify a Title, and click Create Survey.
The Create new survey window in Survey123 Connect.
  1. Publish the survey.
Article ID:000023862
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Survey123 Connect
  • ArcGIS Survey123 Website
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
