Error Message
ArcGIS Data Store fails to validate, with the following SEVERE error returned in the server log:
Error:
ArcGIS Data Store has detected a replication failure
Cause
This issue occurs when the primary data store and the standby data store are out of sync.
Solution or Workaround
Follow these steps to resolve this issue:
- Run the Windows Command Prompt as an administrator.
- Navigate to the ArcGIS Data Store utilities folder using the following command:
cd <ArcGIS Data Store installation directory>\DataStore\tools
- Run the configurebackuplocation command utility to specify the backup folder path. Refer to Portal for ArcGIS: configurebackuplocation for more information.
configurebackuplocation --operation change --store relational|tileCache|spatiotemporal --location <backup location>
- When prompted with Do you wish to continue (Yes or No)?, type Yes, and press Enter.
- Run the removemachine command utility to remove the standby machine using the following command line:
removemachine <machine name> --store {relational | tileCache | spatiotemporal} [--force {true | false}] [--prompt {yes | no}]
- On the ArcGIS Data Store standby machine, navigate to the following directory on the machine:
C:\
- Rename the arcgisdatastore folder to arcgisdatastore_old.
- Reconfigure the standby data store. Refer to Portal for ArcGIS: Add a machine for steps to do this.
