PROBLEM
A data-driven element backed by published data referencing a geodatabase source displays as 'No Data' and 'Cannot Access Data' in ArcGIS Dashboards.
In a dashboard, elements such as an indicator, gauges, pie charts and serial charts rely on the underlying data source's ability to generate summary statistics when queried. If the layer is incapable of performing statistics, the necessary summary statistics are not generated.
Use query layers to query data from the database or geodatabase. Refer to ArcGIS Blog: Using query layers in Operations Dashboard for more information.
Article ID:000023698
Get help from ArcGIS experts
Download the Esri Support App
