HOW TO
When a web map contains feature layers with non-disclosure information, hiding fields in the ArcGIS Collector app is necessary to prevent data collectors from viewing or editing them. This article describes how to hide the fields in the ArcGIS Collector app without deleting them from the web map in ArcGIS Online.
Note: If only the check box under the Edit column is checked, the fields remain hidden and are only visible when editing data in the ArcGIS Collector app. Uncheck the check boxes under the Display and Edit columns to hide the fields of editable feature layers when viewing or editing data in the ArcGIS Collector app.
The image below shows the NAME field is hidden in the pop-up when viewing the feature layer in the ArcGIS Collector app.
Get help from ArcGIS experts
Download the Esri Support App
