HOW TO
When a map contains different layers, it is necessary to display smaller symbols on the map to ensure all of them are visible to the viewer. However, map symbology size is carried over in the legend when it is added to the project layout. The information in the legend may be unclear due to the size.
This article provides a workflow to change the size of point symbols in the legend without changing the size of the map symbology in ArcGIS Pro.
Note: Alternatively, convert the legend to graphics for more precise control over each item comprising the map element. Refer to ArcGIS Pro: Converting map elements to graphics for more information.
The image below shows the point symbols display larger in the legend than on the map.
Get help from ArcGIS experts
Download the Esri Support App
