HOW TO
Patches for ArcGIS Server can be installed silently in environments where a user interface is not available. Installing silently is also useful when using automated processes.
msiexec.exe /quiet /passive /p <location of downloaded patch file>
Note: The msiexec.exe command is a Windows installer, and is used to execute .msi files. The default path for this is C:\Windows\System32. Using the 'msiexec.exe -h' command in Windows Command Prompt displays the different parameters associated with msiexec.exe and their meaning.
Note: The '/p' parameter is not displayed when using the 'msiexec.exe -h' command. This parameter indicates a patch is being applied.
Article ID:000023214
Get help from ArcGIS experts
Download the Esri Support App
