PROBLEM
When deploying an ArcGIS Solution in ArcGIS Pro, the Coronavirus Response solution is not available.
The Coronavirus Response solution cannot be deployed to ArcGIS Enterprise. The solution is not available if the current active portal of ArcGIS Pro is set to ArcGIS Enterprise.
Change the active portal of ArcGIS Pro to an ArcGIS Online organization and deploy the Coronavirus Response solution. Refer to ArcGIS Pro: Manage portal connections from ArcGIS Pro for more information.
Get help from ArcGIS experts
Download the Esri Support App
