ERROR
Authentication token required. (status code 499)
Last Published: August 5, 2020
Error Message
Attempts to sync hosted layers from ArcGIS Desktop to ArcGIS Online or hosting Web Map Services (WMS) and Web Map Tile Services (WMTS) layers fail and return the following error:
Error:
Cause
The error occurs when the layers are added from a previous project, for example, the layer is opened through ArcGIS Online by selecting the Open in ArcGIS Desktop option and added to the map. It is recommended to add the layer from the same data source of the added layers, instead of adding the layer from a previous project, since there may be issues with the old project that may be carried over.
As for hosting WMS or WMTS layers, this is a known limitation. The Open Geospatial Consortium (OGC) WMS services are secured with token-based authentication, and must be shared with everyone to be properly used.
Solution or Workaround
Use one of the following suggestions to fix the error.
Article ID: 000022899
Software:
  • ArcMap
  • ArcGIS Online
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
Esri Support AI Chatbot
