ERROR
Attempts to add a report template file (.brpt) to ArcGIS Business Analyst using the 'Add template from file' option fail with the following error message:
Error: The report template can't be saved due to some server issues.
The report template file is provided by a different organization.
The report template is referencing feature layers that are not available in the organization it is added to.
To resolve this issue, remove all the feature layers attached to the report template. The following workflow must be performed in the report template creator's organization. In this example, there is only one feature layer attached to the report template.
The report template can be shared and added to ArcGIS Business Analyst reports from other organizations.
Article ID: 000022873
Get help from ArcGIS experts
Download the Esri Support App
