ERROR
The Create Feature task could not be completed. Insufficient permissions
Error Message
In some instances, adding new features to a feature class in an enterprise geodatabase returns the following error message:
Error:
Cause
The user is not granted the necessary permissions to create features.
Solution or Workaround
Complete the steps below to grant the required permissions in SQL Server Management Studio.
  1. Log in to SQL Server Management Studio.
  2. Right-click the database and click Properties.
  3. Click Permissions and select the user. Under Grant, check the check boxes for the following permissions: Create table; Create procedure; Create view, and Create function.
An image of the granted privileges.
  1. Click OK.
  2. Grant the Execute permission on stored procedures associated to the data for editing. Refer to Grant Permissions on a Stored Procedure for steps to do this.
The user is now able to create new features and edit existing features in the feature class.
Article ID:000022707
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
