HOW TO
Add a web layer with stored credentials to ArcGIS Online using ArcGIS API for Python
Last Published: January 13, 2025
Summary
Web layers can be added to ArcGIS Online from an existing ArcGIS REST Services Directory through ArcGIS API for Python using the gis.content.add() function. However, if the desired layer contains a stored credential, the function is hindered and the process of adding the web layer fails.
Procedure
The following steps describe how to add a web layer with stored credentials to ArcGIS Online using ArcGIS API for Python.
  1. Import the necessary modules.
from arcgis.map import Map
from arcgis.gis import GIS
  1. Connect to the ArcGIS Online account and create a token.
gis = GIS('https://www.arcgis.com','username')
token = gis._con.token
  1. Create the item properties for the desired web layer. The item properties specifies the required credentials to access the web layer.
item_properties =
"title":"TestAdd2", #the same title
"tags":"test",
"url":"https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire_secure/FeatureServer",
"type":"Feature Service",
"description":"Test Me",
"serviceUsername":"username",
"servicePassword":"password",
"token":token
  1. Add the web layer.
gis.content.add(data="https://sample.arcgisonline.com/",owner="username",item_properties=item_properties)
The following shows the full code:
gis = GIS('https://www.arcgis.com','arch0000')
item_properties =
"tags":"test",
"url":"https://sample.arcgisonline.com/arcgis/rest/services/Wildfire_secure/FeatureServer",
"token":token
gis.content.add(data="https://sample.arcgisonline.com/arcgis/rest/services/Wildfire_secure/FeatureServer",owner="username",item_properties=item_properties)
Article ID: 000022504
Software:
  • ArcGIS Online
  • ArcGIS API for Python 1 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
