PROBLEM
Attempts to log in to an ArcGIS Enterprise portal on the Collector for ArcGIS (iOS) app and Portal for ArcGIS home page using devices with iOS version 13 and above return the following error message:
Error: The server you are trying to connect to (<domain_name>) is using an untrusted certificate.
Additionally, attempts to log in to an ArcGIS Enterprise portal on the Survey123 for ArcGIS app using devices with iOS version 13 and above return the following error message.
Error: SSL handshake failed (6) Error 17: The root CA certificate is not trusted for this purpose
The certificates do not meet the trusted certificates requirements for iOS 13. For more information, refer to Apple Support: Requirements for trusted certificates in iOS 13 and macOS 10.15.
To circumvent the issue, complete the steps below.
Note: Ensure all the ArcGIS Enterprise components and environments are configured with the certificates obtained in step 1.
Get help from ArcGIS experts
Download the Esri Support App
