HOW TO
Uninstall or overwrite a StreetMap Premium license file for ArcGIS Server (Windows)
Last Published: September 25, 2025
Summary
The same DataLicInstall utility in the command prompt can be used to install, overwrite, or uninstall StreetMap Premium license files (*.sdlic) on ArcGIS Server machines, if ArcGIS Desktop is not installed. Run the command datalicinstall.exe -h (help) for more information about the utility.
Procedure
Uninstall an .sdlic license file
  1. Open the command prompt (cmd).
  2. Navigate to the datalicinstall.exe path in the command prompt.
cd C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin
  1. Run the following command:
datalicinstall.exe /u:<licenseFilePath><licenseName>.sdlic
Override an .sdlic license file with another license file
  1. Follow the first two steps above.
  2. Run the following command instead:
datalicinstall.exe /o <licenseFilePath><licenseName>.sdlic
Article ID: 000022381
Software:
  • ArcGIS StreetMap Premium
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
