HOW TO
Use IF statements in the Field Calculator in ArcMap
Last Published: May 10, 2024
Summary
ArcMap is in Mature support and will be retired March 1, 2026. There are no plans for future releases of ArcMap, and it is recommended that you migrate to ArcGIS Pro. See Migrate from ArcMap to ArcGIS Pro for more information.
The Field Calculator uses IF statements to calculate new values in the field of an attribute table. This article describes some common uses of IF statements in the Field Calculator and with Python scripts.
Procedure
To access the Field Calculator, refer to ArcMap: Making field calculations for more information. The following scripts use the Python parser with the Show Codeblock option checked and the expression provided.
Indentations are not automatically inserted into the Pre-Logic Script Code box. Follow the exact indentations specified in the script sample for the code to function properly.
Convert a field value based on a specified condition
Use the IF statement to convert the value of a text field based on the condition set. The following script populates the field with 'Yes' or 'No' if the value in the Valid field is '1' or '0' respectively.
def convert(Valid):
    if (Valid == '1'):
        return 'Yes'
    elif (Valid == '0'):
        return 'No'
    else:
        return 'N/A'
In the Expression text box below the Pre-Logic Script Code section, enter the following:
convert(!Valid!)
The field calculator window for example 1
Populate a field based on the value of another field
Use the IF statement to populate a field based on the value of another field. The following script populates a field with 'Y' or 'N' if the value in the ObjectID_2 field is '1' or '0' respectively.
def reclass(OBJECTID_2):
    if (OBJECTID_2 == 0):
        return "N"
    else:
        return "Y"
reclass(!OBJECTID_2!)
The expression to populate a field with Y or N based on the OBJECTID_2 field the Field Calculator
Classify a field according to a range of values from another field
A field can be populated with different values according to a range of values from another field. The following script classifies a field according to the different ranges of elevation in the Top_Elevat field, with less than 8,000 ft. classified as Class 1, and so forth.
def reclass(TOP_ELEVAT):
    if (TOP_ELEVAT < 8000):
        return 1
    elif (TOP_ELEVAT > 8000 and TOP_ELEVAT < 9001):
        return 2
    elif (TOP_ELEVAT > 9000 and TOP_ELEVAT < 10001):
        return 3
    elif (TOP_ELEVAT > 10000):
        return 4
reclass(!TOP_ELEVAT!)
The expression that classifies a field according to the different ranges of elevation in the Top_Elevat field in the Field Calculator
Copy values from one field to another if the value contains a number
Use the .isdigit() function to copy values from one text data type field to another only if the value begins with a number, as shown in the example below.
def myCalc(num):
    if (num[0].isdigit()):
        return num
    else:
        return " "
myCalc(!<fieldnamehere>!)
The expression to copy values from one text data type field to another if the value begins with a number in the Field Calculator
Copy values from one of two fields to another field
An IF statement can be used to copy the values from one of two fields that meets a certain criteria. The following script copies a value from the Acres or Legal field to a new field based on the value in the Legal field.
def calc(legal, acres):
    if legal == 0:
        return acres
    else:
        return legal
calc(!Legal!, !Acres!)
The expression to copy a value from the Acres or Legal field to a new field based on the value in the Legal field in the Field Calculator
Change the value of a field if it meets the criteria of two fields
An IF statement can be used to change the value of one field that meets the condition of two other fields. The following script changes the value in the ActivityStatus field to 'Closed', if there is a value of less than -10 in the CountDown field and has an 'Approved' value in the ActivityStatus field. If it does not meet both conditions, the ActivityStatus field is left as it is.
def myCalc(status,activity):
    if (status<-10)and(activity=='Approved'):
        return 'Closed'
    else:
        return activity
myCalc(!CountDown!, !ActivityStatus!)
The expression to change the value in the ActivityStatus field if there is a value of less than -10 in the CountDown field in the Field Calculator
Article ID: 000022370
Software:
  • ArcMap 10 6
  • ArcMap 10 x
  • ArcMap 10 7
  • ArcMap 10 8
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
Esri Support AI Chatbot
