BUG
After updating to iOS 13, Workforce for ArcGIS is unable to connect to portals configured with Integrated Windows Authentication (IWA)
On devices running iOS 13 and later, Workforce for ArcGIS is unable to connect to portals configured with Integrated Windows Authentication (IWA). When signing into a portal with IWA, error 301 kCFErrorDomainCFNetwork is encountered.
This behavior does not occur with iOS versions 12 or earlier.
Cause
BUG-000125988 After updating to iOS 13, Workforce for ArcGIS is unable to login to portals configured with Integrated Windows Authentication (IWA), and error 301 kCFErrorDomainCFNetwork is returned.
Workaround
The workarounds at this time are:
  • Disable Integrated Windows Authentication (IWA) on the portal, and use the built-in identity store.
  • Use another identity store, such as SAML.
  • Use iOS devices with iOS 12.
Article ID:000022320
Software:
  • ArcGIS Workforce
  • Portal for ArcGIS
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
