Frequently asked question
Why do ArcGIS Pro pop-up texts appear small?
Answer
When working with ArcGIS Pro pop-ups, the texts appear smaller than normal and are harder to read, especially on larger displays depending on the resolution settings. For example, a 4K resolution display on Windows 10 may cause texts to appear almost unreadable. This occurs when the operating system automatically applies a high DPI scaling to ArcGIS Pro.
To resolve this issue:
  1. Navigate to the default ArcGIS Pro installation folder.
  2. Right-click the ArcGIS Pro application icon and click Properties.
  3. Select the Compatibility tab and click Change settings for all users.
Image of ArcGIS Pro properties
  1. In the subsequent window, click Change high DPI settings.
Image of the change high DPI settings button
  1. Check the Override high DPI scaling behavior check box.
  2. Select System from the Scaling performed by: drop-down.
Image of the override high DPI scaling behavour button
  1. Click OK.
Article ID:000022142
Software:
  • ArcGIS Pro 2 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
