ERROR
SAML log-ins to Portal for ArcGIS fail when Oracle Access Manager version 12c (12.2.1.3.0) is the SAML Identity Provider.
Error Message
When Oracle Access Manager (OAM) is used as the SAML Identity Provider (IDP), log-ins to Portal for ArcGIS fail with the error message:
"Unable to login using Idp. Unable to validate SAML response".
This occurs with OAM version 12.2.1.3.0 and all versions of Portal for ArcGIS.
Cause
The digest value in the SAML assertion response received from OAM 12c contains an unexpected new line character. This is due to a known bug in Oracle Access Manager: #27032742 IDCS ADDS A NEW-LINE CHARACTER AT THE END OF `DIGESTVALUE'.
Solution or Workaround
Install the latest OAM patch from Oracle that includes the fix for bug 27032742 , for example: Patch “29825297 Oracle Web Service Manager BUNDLE PATCH 12.2.1.3.0 ”.  Please note that an Oracle Support Subscription is required to access these links.
Article ID:000022094
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
