ERROR
Error 1304. Error writing to file...Verify that you have access to that directory
Error Message
When installing ArcGIS products, the following error is returned:
Error:
Error 1304. Error writing to file...Verify that you have access to that directory.
Screenshot of error 1304 when installing ArcGIS Desktop 10.7
Cause
There are several possible causes for the error when installing ArcGIS products:
  • The user has no access to the directory required for installation on the machine.
  • The installation file is detected as a security threat by the anti-virus software in the machine.
  • The required Microsoft .NET Framework is not installed or working properly in the machine.
Solution or Workaround
Use the following solutions, depending on the ArcGIS product being installed:
ArcMap or ArcGIS Pro
  • Run the installer file as an administrator of the machine. Contact the IT Department for administrator rights.
  • Disable the anti-virus software before installing.
Mapping and Charting Solutions
  • Ensure the proper version of Microsoft .NET Framework is installed on the machine. For more information, refer to Mapping and Charting Solutions install guide: Minimum system requirements.
  • If the proper version of Microsoft .NET Framework is installed, repair Microsoft .NET Framework.
    1. Navigate to Control Panel > Programs > Programs and Features.
    2. Select Microsoft .NET Framework.
    3. Click Change.
    4. Click Repair. Complete the process and click Close.
    5. Install Mapping and Charting Solutions.
Article ID: 000021786
Software:
  • ArcMap
  • ArcGIS Pro 2 x
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
Esri Support AI Chatbot
