HOW TO
Identify the usage of items in ArcGIS Online using ArcGIS API for Python
Last Published: June 23, 2020
Summary
In ArcGIS Online, it is possible to identify the usage of any item by accessing the items details page and clicking on the Usage tab.
Image of the Usage details window
It is also possible to determine the usage of items programmatically using ArcGIS API for Python for Portal for ArcGIS.
Procedure
The following steps describe how to identify the usage of content items in a portal:
  1. Import the necessary module.
from arcgis.gis import GIS
  1. Connect to ArcGIS Online.
gis = GIS("https://arcgis.com", "user_name")
print("connected")
  1. Search for the content, and sort the items.
content = gis.content.search(query="", sort_field="title", sort_order="asc", max_items=2)
content
  1. Iterate through the items, and print the usage according to the desired timeframe.
for item in content:
	print (item.homepage)
	print (item.usage ('24H'))
	print (item.usage ('7D'))
	print (item.usage ('14D'))
	print (item.usage ('30D'))
	print (item.usage ('60D'))
	print (item.usage ('6M'))
	print (item.usage ('1Y'))
The screenshot below displays the usage of items.
Image of a sample result
Article ID:000021762
Software:
  • ArcGIS Online
  • Portal for ArcGIS
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
