HOW TO
When trying to update the data source for all layers in an ArcGIS Pro project, it is necessary to manually update each layer if the data source is not broken. To simplify this, the ArcPy updateConnectionProperties function can be used to programmatically update all layers in a project.
There is a bug with the updateConnectionProperties function when attempting to update the data source from one Enterprise geodatabase to another. The code executes without error message, but no properties are updated. The connectionProperties dictionary must be used for the parameters.
Using the connectionProperties dictionary to update the data source from one Enterprise geodatabase to another:
import arcpy aprx = arcpy.mp.ArcGISProject(r'C:\Projects\project.aprx') find_dict = {'connection_info': {'authentication_mode': 'DBMS', 'database': 'Giza', 'db_connection_properties': 'Egypt', 'dbclient': 'sqlserver', 'instance': 'sde:sqlserver:Egypt', 'password': 'hermitPurple123', 'server': 'Egypt', 'user': 'Romeo', 'version': 'sde.DEFAULT'}, 'workspace_factory': 'SDE'}} replace_dict = {'connection_info': {'authentication_mode': 'DBMS', 'database': 'Khufu', 'db_connection_properties': 'Egypt', 'dbclient': 'sqlserver', 'instance': 'sde:sqlserver:Egypt', 'password': 'theWorld123', 'server': 'Egypt', 'user': 'Maya', 'version': 'sde.DEFAULT'}, 'workspace_factory': 'SDE'}} aprx.updateConnectionProperties(find_dict, replace_dict)
Replace the find_dict connection info with the source database connection, and the replace_dict connection info with the target database connection. If this information is unknown, run the following script:
Print the connection_info to find the information about a database connection
import arcpy, pprint p = arcpy.mp.ArcGISProject('current') m = p.listMaps()[0] l = m.listLayers()[0] pprint.pprint(l.connectionProperties)
Returns connection property information in this format:
{'connection_info': {'authentication_mode': 'DBMS', 'database': 'Khufu', 'db_connection_properties': 'Egypt', 'dbclient': 'sqlserver', 'instance': 'sde:sqlserver:Egypt', 'password': '*********', 'server': 'Egypt', 'user': 'Romeo', 'version': 'sde.DEFAULT'}, 'dataset': 'Egypt.SDE.Centerlines', 'workspace_factory': 'SDE'}
Note: The password will be returned as a string of asterisks (****). The user must type their password as plain text in the parameters as shown in the example, if using database authentication. If the listLayers function returns an indexing error, the project may contain layers that are missing or broken.
Get help from ArcGIS experts
Download the Esri Support App
