PROBLEM
Some categories in a donut chart are not displayed in the Insights for ArcGIS workbook
When creating a chart using the Donut Chart option in the Insights for ArcGIS workbook, some categories are not displayed in the workbook even though the total value is calculated based on the sum of all fields.
The image below shows an example of the donut chart with only a few categories displayed.
The donut chart is not drawn completely
Cause
This problem occurs if some fields in the Excel file column contain null values that represent no data or no value. If a column containing null values is used to create the donut chart, it is not drawn completely.
Solution or Workaround
Remove the fields containing null values in the Excel file column used to create the donut chart. After removing the fields, in the Insights for ArcGIS workbook, add the Excel file using the Add button and recreate the donut chart in the workbook.
The image below shows a complete donut chart after the fields containing null values are removed.
The donut chart is completely drawn
Article ID:000021337
Software:
  • ArcGIS Insights 3 3
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
