PROBLEM
Attempts to download file geodatabases from an ArcGIS Server map service in ArcGIS Hub fail.
This is a known limitation. In ArcGIS Hub, a map service cannot be downloaded as a file geodatabase. Refer to ArcGIS Hub: Enable file geodatabase downloads for more information.
Alternatively, prepare the metadata to have additional download files and related documents, which are displayed as Additional Resources in the download section of the Data page, on ArcGIS Hub.
Note: This format is important as it ensures the options required in the following steps are available.
Note: When publishing the map service, in the Service Editor window, click Capabilities, and enable Feature Access. On the Feature Access tab, enable Query for Operations allowed.
Note: When a map service is published, information under the Distribution Format and Digital Transfer Options headings at the top of the Distribution page are not included.
Note: To add the document and the additional download files in the same .xml file, right-click the existing XML document in ArcMap, and click Edit > Resource> Distribution. Expand Digital Transfer Options, and click New Online Resource.
Get help from ArcGIS experts
Download the Esri Support App
