BUG
Spatial aggregation on Oracle geodatabase 10.5.0 fails between spatial references 102100 and 4269
Spatial Aggregation does not work for Oracle geodatabase 10.5.0 between datasets using spatial references 102100 (Web Mercator) and 4269 (NAD 83). The same problem may happen to Oracle geodatabases 10.5.1 or 10.6.
Cause
ST_Transform fails when the data sources have spatial references using a different datum.
Workaround
For Insights 3.2 or later, upgrade the Oracle geodatabase to 10.6.1 or later.
Article ID:000020894
Software:
  • ArcGIS Insights
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
