ERROR
You cannot submit records to the survey since you are not field worker or the survey owner
Last Published: May 10, 2022
Error Message
Respondents are unable to submit a survey published from ArcGIS Survey123 Connect using an ArcGIS Survey123 web form, and the following error message is returned:
Error:
You cannot submit records to the survey since you are not field worker or the survey owner.
Error mesage
The problem persists although the sharing permissions are reset and the user is the survey owner.
Cause
  • The field worker hosted feature layer is renamed or changed in ArcGIS Online.
  • The certificate issued on the ArcGIS Server and Load Balancer machine is not fully trusted. This is because the feature service used in creating the survey is from a secured ArcGIS Server service. This prevents ArcGIS Online from storing the credentials used for the ArcGIS Server machine.
Solution or Workaround
Depending on the cause, resolve the error using one of the methods below.
Article ID:000020842
Software:
  • ArcGIS Online
  • ArcGIS Survey123 Connect
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
