English
Problem: ArcGIS Pro crashes when using the Infographics Report tool in ArcGIS Pro 2.3
ArcGIS Pro version 2.3 crashes when trying to create an Infographics Report or when trying to open the Infographics configuration page.
Cause
The problem is caused by incorrect travels modes set in the user configuration file.
Solution or Workaround
Delete the user.config file. The file is located in:
C:\Users<user name>\AppData\Local\ESRI\ArcGISPro.exe_StrongName_yhpsrysqpn4fvmb0spwbakt5o5e50din\2.3.0.0
Related Information
Last Published: 4/23/2019
Article ID: 000020814
