ERROR
Unable to cast COM object of type 'ESRI.ArcGIS.esriSystem.AoInitializeClass' to interface type 'ESRI.ArcGIS.esriSystem.IAoInitialize'
Error Message
Attempts to run an ArcGIS Engine app return the following error:
Error:
Unable to cast COM object of type 'ESRI.ArcGIS.esriSystem.AoInitializeClass' to interface type 'ESRI.ArcGIS.esriSystem.IAoInitialize'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{someGUID}' failed due to the following error: Library not registered. (Exception from HRESULT: 0x8002001D (TYPE_E_LIBNOTREGISTERED)).
Cause
The app is not declared as a Single Threaded Apartment (STA) app. This can occur if a new application is created in ArcGIS Engine without using the Esri-provided template.
Solution or Workaround
To resolve this issue, add an attribute at the top of the ArcGIS Engine app to declare it as a Single Threaded Application (STA). For example:
class Program
    private static LicenseInitializer m_AOLicenseInitializer = new EngineConsoleApp_ESRI.LicenseInitializer();
    [STAThread()]
    static void Main(string[] args)
Article ID:000020746
Software:
  • ArcObjects SDK Microsoft NET Framework
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
