PROBLEM
In some instances, after copying survey questions from an XLSForm and pasting them in another in ArcGIS Survey123 Connect, the drop-down button of some cells of the pasted survey questions do not display a list of options.
This issue occurs because the pasted survey questions in the XLSForm still reference the original Data Validation Source from which the survey questions are copied. In most cases, when copying survey questions from a republished XLSForm in ArcGIS Survey123 Connect, the Data Validation Source is preserved even after pasting the survey questions in another XLSForm.
To circumvent this issue, ensure the pasted survey questions in the XLSForm reference the intended Data Validation Source. To do so, follow the steps described below:
Note: In this example, the questions type in the 'survey' worksheet must reference the list of Field Types in the 'types' worksheet.
Get help from ArcGIS experts
Download the Esri Support App
